Re: Johnson 112 HP SPL is it a good motor?
OMC was in flux durring those years. But the problems they had were major, and if you have a used one, chances are it's "one of the good ones". But do NOT buy it without having a compression test performed in your pressence. Look for all the normal signs of bad news, such as a dot of oil on the ground under the skeg,and an oily prop/skeg area.<br />Remove the cover, and make sure the engine was not "touched-up" with paint, or paint which has scorched,bubbled or blistered on or near the head (signs of engine overheated at one time).<br />If it looks clean,albeit the patina of it's age, the compression test shows good and equal compression, it IS one of the good ones.
