CalicoKid
Thread starter- Joined
- May 27, 2002
- 1,599
Hi all, man this board got busy! I'll add to the soup too. Just ran the motor for the first time this season like everyone else. I ran it on muffs in the driveway for around 10 minutes to burn off the fog oil and check everything else out. After it was warmed up a little I noticed that the tops of the Starboard heads were cooler to the touch than the Port heads. Niether was hot, I could hold my hand there all day long.<br /><br />I've read here on this forum something about my kind of motor having issues with temp. control that can cause big trouble. My Pop rebuilt a 115 that had a blown piston and scored cylinder he says was caused by a stuck t-stat.<br /><br />I've also read that replacing the t-stats on my motor is a pain...<br /><br />Should I be worried about taking it out even once? I'd like to take it out tomorrow for a test run. I don't know how much you can tell idling on muffs running ice cold water through the motor, would it be a good idea to run it like normal on the lake and check temps then? What would be a good way to check the temp.?<br /><br />My motor is a 1988 110 hp V4 with the VRO working. This motor has very low hours on it. I have the correct plugs in it. Always runs great except the last run of last season it suddenly killed on me at WOT, restarted got up to WOT 5600 rpm and it killed again as I trimmed up (I can turn 5800 RPM). Wouldn't restart, got towed for 30 minutes and it started at the dock. I haven't been on the lake since but it runs fine in the driveway. I'm only throwing this in incase it might be related to the teperature. And I'd like to test it tomorrow to see if it's going to happen again after snugging up all of my wiring terminals and grounds. Think I'm safe? Should I do T-stats sometime, soon, ASAP or RIGHT NOW! ?? I have a Clymer manual, is this OK for the job?<br /><br />Thanks yall, I wouldn't know jack about boats if it weren't for this furum!
