Johnson 100HP Won't start
Coronado
Hi everyone<br />I just bought a used Johnson Outboard 100HP which I belive is a 1979. The motor starter cranks but the engine won't start, I used the technic of pumping gas manualy with the hand pump in the gas line, the gas system is OK, Then I took one of the spark plugs connected it to the cable and ground it to the motor and I have NO SPARK!!!<br />The motor hadn't run for two years.<br />Any help will be apreciated.
D
DJ
Guest
Re: Johnson 100HP Won't start
LFL,<br /><br />Look for a fuse in a barrel type connector. It is usually close to the starter.<br /><br />By the way, does this engine have a kill switch? If it does, it is attached to a lanyard and connects to the control box.
