Red Neck Okie
- Dec 2, 2008
- 4
Re: Jetski motor in a jon boat.
I had that problem and then I installed a 1/4 inch square mesh wire under the intake grate that stopped the sucking of rocks at slow speed in shallow water. Any leaves that get caught on the screen usually wash off when I stop the engine as I almost always boat upstream against the current. By going upstream against the current, if you have a engine or pump problem you always float down to where you put in. WALA NO PROBLEM!
Looked into this a couple of years ago and found a site that showed some builds in progress, using small jon boats. Problem was crap/debris fouling the pump pickup at slow speeds...maybe they've found a way to cure that by now.
