Re: Jet powered vs. inboard
My suggestion is to look at (for example) Alumaweld Boats. They make various hulls with many different degree hull angles. Flat bottom, 6,10,14 and 18 degree bottoms depending on the models you may choose. Then you can pick (for example) outboard jet power,regular outboard prop, Sport-jet power, inboard jet in V6 or V8 with different jets units,sterndrive. One feature that Alumawelds have that other alum. builders don't is this... Let's say you get a 10 degree bottom on the model you choose, It will actually be 10 degrees from the area near the windshield all the way to the transom. This means you have the shallow water "run-ability" and 10 degree benifits at a slower speed. You do not have to run Wide Open Throttle to "get" to the 10 area, which is often just at the rear of other boats. Many hulls will start out at say 30 degrees at the bow and slowly flatten out to 10 degrees only at the last 4 or 5 feet of the hull. <br /> To answer your first question. You will not have an inboard/prop set-up (like a tourniment ski boat)but an inboard jet (nothing "hanging" under the bottom). And boats in the 22' range are not cheap!! As an example, you should check out Alumawelds web page. Expect other builders to be "not cheap"!!! Alumaweld builds more of this type of welded hull than ALL the other builders combined!!! Top Shelf!!!!Also look at NorthWest Jet Boats, Weldcraft, Woolridge, Duckworth..... But I think Alumaweld is the best.... My two cents!P.S. Do your homework!!!!
