lakelover
- Mar 26, 2003
- 4,390
The boat is a 15? Starcraft Jet Star, motor is a 200 lb. 50 hp long shaft Johnson. (The Jet Star has the seats forward, back to back, not two in the back like the Jet, so passenger weight would be more forward).
I?ve done tons of research and reading here about both extending the height of the transom or using a jack plate in order to use a 20? motor on a 15? transom. With all the sometimes conflicting information I?ve found I?m totally confused about which method to decide on for my case. I have seen the same poster in different threads claim that jack plates do and do not add stress to the transom.
So there are some things I hope people can clarify about jack plates:
-How does the setback of a jack plate affect the balance/performance of a boat? Use of the boat will be primarily cruising around with 2-4 people.
-How does it affect getting up on plane?
-Does a motor mounted that way add stress to the transom? (It seems to me, yes). Or is it just not very appreciable with a 200 lb. motor set back 3-4??
-Jack plate = less work, but are there advantages/disadvantages in terms of safety, handling, or performance?
