horiconducker
Thread starter- Joined
- May 12, 2008
- 96
I have run out of ideas so i thought i would post up on here. Motor had not been ran in five years. Has good compression 113- 115 psi on all three cylinders. I deleted vro by blocking off oil line on motor, replaced water pump, thermostat and rebuilt carbs with kits off of iboats. Did a complete link and sync according to oem manual. I have 2 problems, but im pretty sure they are connected and both fuel related. I have idle set at 700rpms in water and it idles ok, i think it could be smoother, it shakes a little at idle, but idles for 10mins. (my twin v4 crossflows are smoother at idle then this motor). On the lake If i advance the throttle to 800-900rpms it starts losing rpms and stalls within 15 seconds. After it stalls i have to use the primer to restart it. When it starts losing rpms i can keep it going with the primer, but its a fine line between flooding and running. My other situation is that it will bog and sometimes die out when doing a holeshot like pulling a skier from idle 700rpms. If i can get to it quick enough before it stalls primer will bring it back to life and away i go. If i advance the throttle to 1000rpms or so holeshot is great then.
