J70elcnb air box gasket leak
laurentide
Howdy guys, I have a question about this air box gasket that leaks fuel-oil mix when tilted up for travel/beaching. I've replaced the gasket, and it still leaked. Replaced it again and used some "fuel resistant" gasket maker at the bottom. It still leaks. I suspect that stuff does in fact break down eventually. At this point I'm about to just put an oil absorbent pad under the carburetor area and replace it once a year or something.
Before I do that I was just wondering if anyone has a better method of sealing the seam at the bottom. This is obviously more of an annoyance than a big problem, but more than once I've dropped the engine at the ramp and had a big oil slick from the stuff that collected in the lower cowl, and it's both embarrassing and illegal. I do run the engine out of gas, but there's still gas in the carbs when it dies.
Thanks!
Honorary Supreme Mariner
Is the wee hose hooked up at the back of the air box ?
laurentide
Yeah, I replaced it a couple of years ago. Carbs are rebuilt and working fine. I can watch it drip from the bottom of the silencer after being tilted for a minute.
emdsapmgr
use some gasket sealer and glue the gasket to one side of the airbox cover. That will slow it down.
