jakedaawg
Thread starter- Joined
- Jun 26, 2012
- 4,275
Indications:
Only will spin up to 3000 RPM under load. Doesn't hit rev limiter. Runs smooth. No active faults via 4SDS. All voltage tests within spec. The only time I can get the rev limiter to kick in is in neutral. After initial start up it sometimes stalls on acceleration. Does not stall on deceleration. Only shows 26 PSI fuel pressure. No residual pressure.
I am thinking I need to pull the VST and inspect float, needle, seat, test pressure regulator and clean screen.
Thoughts?
Thoughts?
