55'Fleetwin7.5
- May 29, 2007
- 241
I run a 1965 Starflite 90S.. I changed the plugs today. The plugs I removed were J6C. I had it on the lake today with the old plugs and (except for running a bit hotter than I like.. which is another issue..) It idled, shifted and ran reasonably. The plugs were old and I had read that the correct plug was actually a "J4C".. So that is was I installed. When I started it with the new plugs, it idled way fast.. 3500 to 4000... SO I shut it down. Now I believe the impellor needs replacing... Could the change in plugs do that? I tried to shorten the throttle cable to help me get it slower, but it did not accomplish much.
Also,I am not getting the strong water flow I want and after about 30 seconds at that high RPM, I could not stand to touch the cylinder head.. I am not sure about replacing the impellor on this model.. I have done several from 5.5 hp to 35 hp, but none with electric shift. Any advice?
