astropluto
- Jul 24, 2006
- 37
Engine wont start. Its a 95 johnson 200. I'll start at the begining. It used to run great, now not at all. It used to start when I squeesed primer ball 3 times, then pushed the key down and turned it. Started every time. 2 weeks ago it was hard to start, but I got it started. 10 minutes later while still going slow to get to the bay, the motor just stopped.
Now for the fun part.
I pumped up the primer ball still wont start. After several tries I noticed unmixed oil coming out of the exhuast ports and no gas smell. I changed the fuel water separator still no gas. I checked that fuel was getting to the VRO which it was. There was only oil after the VRO. Changed VRO and pulse limiter. With the help of a friend we got her started but, we had to pump the primer ball wile getting it started. I figured air in the fuel lines because I had it all apart and maybe the primer ball is shot. We went out for 30 minute high speed run. It ran great. So I would have thought.
I changed the primer ball and sparkplugs just because it was the right thing to do. The next time I went to go out fishing it wont start again.
I found a collapsed fuel line. So I changed all of the fuel lines. Then I found that my Fuel water separator was plumbed backwards. Then I checked and cleaned the pickup in the fuel tank. Checked and cleaned the oil lines and tank. I have spark.
When trying to start I have to crank for longer than I want before she lights off. It will only run for 5 or 10 seconds and then just shuts off. I have drained the carbs, i get brown fuel out of them, not golden, not blue but brown. Now when I get it to lite off the overtemp warning horn goes off. It's not overheated, because it doesnt run.
Any thoughts would be great, Thanks
