FreeBeeTony
Thread starter- Joined
- May 15, 2002
- 3,997
Tha same problem I had last year is back.
While returning from a fishing trip this morning........the engine sputtered momenterily while deccelerating. My son and I looked at eachother in disbelief. I slowed down to an idle, seemed fine, temp, oil gauges, etc, all ok. Throttled back up and sure as sh!t it started to miss at ~3000RPM. On the way back I performed my "contribution test" by shorting out each plug at the distributor and found #3 not making power under load.........just like last year!
Once back at the dock I pulled the valve cover to check rocker adjustment. I found the intake rocker on the #3 cylinder to be too tight.......took ~2 turns for it to start to make noise. I then tightened 1/4 turn after making it quiet and proceeded to check the rest of them. I found the rest of the rockers to be adjusted as I left them in the spring....1/4 turn past being quiet. However, the intake on #3 is not repeatable..........I adjusted this valve multiple times...........there were times I had the rocker nut almost flush with the stud before it started to "clack". Something doesn't seem right here...........do I have a bad lifter?
I am thinking the lifter was not compressing, causing the intake to hang open. I haven't taken it out after my last adjustment. And when looking at the location of the nut with respect to the stud it is visibly not as tight as the others.
I cannot belive this...................although I am fairly certain it's the lifter this time!
