Issues with shift linkage. 1974 Starflite 85hp
Theoutdoorsman222
Just got a new-to-me pontoon. This old Evinrude runs like a champ. The only issue I'm having is that I cannot get the engine to shift correctly. I have tried to adjust the shift cables. I can either have full foward or full reverse. I've tried to find s happy median between the two. But if you try to adjust it out where it's between the two, you get neither. Any ideas? Thanks?
interalian
Sounds like you have slop in the shift parts. Look for play anywhere there's a pivot, and check the cable too. Might be as simple as a worn bushing.
