Rick K
- Oct 6, 2003
- 235
Some background: Picked up a RDE-19 last nite cheap; figured I would tinker with it and see if I could get it go. For $50, I'm not out a lot, and figured it's a great motor to learn on. After I fixed the wiring harness, she fired right up, as the pull start required a team of strong men.<br /><br />The telltale sprayed like a firehose, and after some adjustments to the mixture, she calmed right down and idled nicely for about an hour. Then it quit pumping water, so I shut it down immediately. Pulled the lower unit - impeller shot, etc. No problem, I can fix that.<br /><br />I checked the compression - 80 top, 120 bottom. Rechecked 3 times. BUT - I didn't have it at full throttle when I checked it, as I was unsure as to whether or not I could crank it "in gear" with the lower unit off.<br /><br />I stoped right there, didn't add any oil to the cylinder, etc.<br /><br />Is it worth going any further with this motor? I can do the de-carb routine, and/or pull the head to see what's up, but if the compression is so far out that bad rings are an indication, someone's gonna have a nice parts motor.<br /><br />Any opinions or direction are always appreciated!<br /><br />Thanks<br />Rick
