Is this speed reasonable ?
Dean36
I just finished restoring a welded aluminum 16' 7" foot Spectrum V hull boat with a 1982 Mercury 50 HP outboard motor. It has no power trim. I took it out for a shake down cruse and every thing worked great. But it felt strange to me. When I went to WOT the bow stayed flat as the RPM's reached 5000 the speed went to and stayed at 26 MPH. I weigh about 190 and my wife is at 135. We had a full tank of fuel. I'm use to a boats' bow coming up and than flatting out as it comes up on plane. I also expected more speed out of this boat.
Does this performance sound reasonable ?
5150abf
Re: Is this speed reasonable ?
I have a 16' Sea-Nymph with an Evinrude 50 with TT and it will run 27-30 pretty consistenly so you are right in there.
Move the tilt pin back one or 2 holes adn you shoudl gain a bit.
The other option is to pony up for a CMC TT unit, I have one on my boat and love it.
indy440
it stayed flat because you have it trimmed down so far. Move the trim pin 2 holes up and you'll notice more bow rise getting on plane and probably a few more mph top speed...
4JawChuck
My 16.5 ft Tuffy fiberglass with a Yamaha 50 hp did 34 mph WOT trimmed perfect and fully loaded with 5 people and gear+fuel. I would agree playing with the trim pin location should get you a couple more mph, you may need to move weight around the boat once you get it set for max speed to keep it from porpoising with less weight on-board. Getting your engine height set right is another factor, the vent plate on the OB should be right at the waters surface with no excessive spray on the transom.
Dean36
Thanks for the input. I'll try it !
