Hey everyone, last season I noticed my lower unit gear lube was draining fast, so I change the lower unit oil. The oil was milky and clearly had water in it, once I pumped new oil in it started leaking from the weep holes and water intake in on the bottom of the lower.
I then changed the impeller and seals, removed the upper and replaced the seals and then this is what the bellows looked like.
Can anyone confirm that this is normal or is this an issue? There was no rust all of the orange is glue from the previous owner, there was traces of water. (Which can’t be good).
I put it all back together with all new seals and lower unit oil is still draining quick. Any ideas??
Thanks in advance!
Thanks in advance!
