Is this fuel injected? 1998 mariah 222
tpenfield
it has the electronics box . . so maybe . . . can you give us the serial number off of the tag down near the starter?
86Capri
Sorry that's all I got engine wise. Sorry. :( there isn't much room in that engine bay without unbolting the box. Thanks.
Fun Times
Yes. The MPI stands for multi port fuel injection. The ECM is inside the black box to the right behind the white oil filter.
I can see the MAP sensor and the fuel schrader valve to check fuel pressure.
86Capri
Awesome! Thanks. I had a feeling, it started super easy. Anything bad I should know about these engines?
Fun Times
They're all good until they break down.:)
Questions to ask the previous owner:
Was the engine ran in salt?
Was the maintenance kept up the best you know of?
One of the biggest concerns would be the conditions of the exhaust manifolds & exhaust gaskets +/between the exhaust riser elbows as if they leak, it could hurt the engine internally.
If possible, take the boat for a lake test ride.
tpenfield
An MPI . . . All the kids at school are going to want to see this engine :D
