Is this concerning? (90hp)
medic one
I'm going to be looking at this 2001 Johnson 90hp Ocean Pro with an eye for purchasing.
Because it's a Craigslist ad I have limited photos. I noticed in the photo of the power head (with the lower cowling removed ) that there is obvious staining on the leg. But when you look at the entire motor it looks very clean. It looks like the staining ends right at the base of the cowling.
Is this something to be concerned about? I can't find any photos on line that show these motors with the middle cowling removed.
Is this normal 2 stroke exhaust / grime collection?
Thanks.
oldboat1
looks to me like the gearcase might have been replaced (color diff. -- Could be the lighting.) Might be something to ask about. Not picking up streaking or discoloring on the leg, at least nothing that looks problematic to me.
medic one
I noticed the differing color of the gearcase as well. In fact it was replace. Reportedly new and professionally installed.
The staining I'm wondering about is in the second photo. At the bottom of the photo where the leg meets the gearcase It looks like there is staining all the way around the leg. This portion of the leg would normally be covered by the cowling that is in place in the first photo. I'm just wondering if discoloration/staining like this is normal and just hidden under the cowling.
Thanks
oldboat1
Well, worth being leary about collision damage if that's relevant (gearcase and possibly replacement cowling). Might not be a deal breaker, as stuff happens. But a consideration in deciding whether to buy -- would compare to an engine with no accident history.
bob johnson
I think that is just the waterline on the motor from being moored in water for an extended period of time..... the boat probably had the same line.....I wouldn't worry about the waterline stain at all......except you might want to look over the motr for galvanic corrosion.....( something you need to check for on boats kept in the water, docked or moored)...
bob
Faztbullet
Water scum line is the stain your seeing, the lower unit is std V-4 "batwing"unit, the lighting is only used on V-6 motors.
oldboat1
Think you want to find out what was replaced and why (you know the gearcase was replaced, maybe that lower cover as well). Failure to clean up the leg underneath the cover is not an issue -- nor is a scum line or exhaust staining, scratches, etc. But any replacement due to accident damage is something you want to know about. In my opinion, if there was serious accident damage, I would not buy it.
