Re: is this bad?? metal shavings on gearcase oil drain plug
finished tearing the foot apart.
top shaft bearing had some surface rust so I'm like "aha!"
but it looks good internally and all the needle bearings spin free as can be without any type of grinding/gripping action as I roll them around with my fingers.
this part is where the water pump impeller sits right? so it should be stuck in place to the shaft like this?
also took out the pinion and forward gear and looked at the bearings/gear teeth/and bearing races a bit better. all looks good to me.
here's the top of the mainshaft where the blue'ing is occuring. couldnt really get a good pic with my cell phone camera due to the lighting but the blue is nice and deep right past the teeth and continues blueish until you see it change color to the standard grey color of the shaft. how do I get access to this bearing to inspect it? do I have to remove the powerhead from the rest of the assembly? I'd read up on it but I've gotta get ready for going out tonight lol.
