Is this a water drain plug?
willieq
If it is, If I take the lower unit off and store it in the basement can I drain this plug and winterize my boat?IMG_1349.jpg Tkanks
Re: Is this a water drain plug?
Yes,....
achris
More fish than mountain goat
Yes, that is the engine block drain.
Don S
You can pull that plug and drain the block, but that is not winterizing the engine, it's just draining the block.
willieq
Just to be clear, Lower unit in basement, block and exhaust manifold drained and boat is winterized.
willieq
OK I see. I need to also change the oil fog the motor etc. However if I take the above steps will this prevent any water/freeze damage to motor?
achris
Ah, no... Winterizing is SO much more than that. Read the sticky on top of this forum....
Chris.........
(Who has never winterized a boat in his life :D)
Don S
Yes. Just make sure the hole is open, use a wire or something to clean it out.
willieq
Thanks Don. I blew some air through the thermostat housing and it blew all that water and trash out the drain plug.
