Hello, I am new to the forum, I have an old outboard motor and was wanting to get some of the history on it, and technical specs. I would like to try to get it running, how much might it be worth to the right person if it was running, is it rare?
if you think your going to restore the motor and make money selling it, hate to break it to you, the cost of restoration would be equal to its value or posibly greater.
if you want to make a small fortune restoring boats and boat motors, start with a large one.
thank you for your replys, I do not have any interest in restoring it, ive done that to a lawn mower, takes a lot of time, but i think it may run, and it should be worth more to the right person running. i read somewhere you are supposed to mix the fuel 16:1 or 8:1 is that true? could i use my 50:1 just to get it running?
just a little bit about the outboard, it came from california, i live in southwestern virginia. there is nothing i love more than getting small engines running, and fixing things with engines,
Thank you F R, I just tried getting it started yesterday after work, I cleaned up the carburetor, I've never seen one quite like it, put a spark plug that I tested on my mower and no spark, so I'm trying to get the flywheel off right now.
It likely has the iron magnets in the flywheel. You are supposed to put a "keeper" across the poles while the flywheel is off. A bolt or something similar will do.
