scipper77
Thread starter- Joined
- Sep 30, 2008
- 2,106
I just wanted to learn a little bit more about marine cams. It seems to me that you use a cam that gives max HP at max RPM's for the engine design. Is it really that simple?
Is there any advantage to using a slightly different cam? for example could you use a less aggressive cam (hp peaks at lower rpm's) and get better gas mileage??
I know I personally never run at WOT because the rate of fuel consumption is incredible. Always wondered if you could sacrifice top end that I never use for fuel economy. Who needs to go 45 MPH on the water anyways?? At that speed if I saw a log floating in the lake in front of me I doubt I could avoid it.
I wasn't sure the best place to ask my question, mods feel free to move if this is the wrong place.
