Is there a way to check front -rear engine mounts of a 305 1979...
sarantis
...or based on the year i have to discard them and buy new? Swapping to a 350 means any change on their type? May somebody give me the weight the front mounts are designed for?
Re: Is there a way to check front -rear engine mounts of a 305 1979...
Ayuh,...
The Front mounts are the Same for the 305,+ the 350,...
If your's aren't Rusted into oblivion,... Just clean'em up,+ reuse'em...
The Rear mounts probably have a Spec on them, if so, Don will probably point it out,...
Otherwise,... Inspect the rubber parts closely,+ make your best judgement,...
They tend to Sag,+ screw up the motor's Alignment....
