Is there a Minimum and Max setting for outboard power trim?
bfontenot45
The power trim on my 2008 90 Mercury Optimax 2 stroke allows the motor to move so far up that it will eventually hit the boat. The switch got stuck on the last trip and the engine trimmed all the way up until the motor cover cracked on the boat. The boat is ok. Fixed the stuck switch but wondering if I can adjust the minimum and maximum trim level to prevent this from happening again. Thanks.
64osby
I don't believe they have limit switches. Sounds like the switch needs some cleaning or maybe replacing.
