buddycraigg
- Jul 15, 2004
- 5
Is the water supposed to flow like this?<br /><br />Its a 1972 Johnson 100 V4<br />model 100ESL72R<br />SN 13685403<br />And I want to make sure the pump is working.<br /><br />With the engine off and muffs hooked up
<br />· A good stream coming from holes with blue arrows.<br />· A mild stream coming from holes with green arrows.<br />· A slight dribble from the green box.<br /><br />With the engine idling
<br /><br />· Still a good stream coming from holes with blue arrows but slightly weaker than when the engine was off.<br />· A very weak stream coming from holes with green arrows.<br />· A mild dribble from the green box.<br />· Exhaust gases and water sputtering out where the red circles are.<br /><br />I kept touching the heads and cylinders and they were only slightly warm after 5 minutes of idling.<br /><br />
<br /><br />
