I have run into an odd problem. There is a gap between the gimbal housing and the hull,
now before you jump to rotten transom hear me out. I've been reading a LOT and from very reliable people on these forum they say it's pretty much impossible for those bolts (pictured) to come loose.
From what I understand the square bit on the back of the built in "washer" goes into the transom plywood allowing you to tighten the nut with the nylon insert from the inside. From what I can see with the picture (can't see it with motor installed) the nut end of the bolt is against a metal flange
on top of the fiberglass. Am I understanding how it works wrong? I just don't understand how the bottom of the motor could be tipping out even if there was no transom installed.
I have done the weight test, and if it moves at all it's no more than 1/16th of an inch. Previous owner (I just bought it a couple weeks ago) is no help. So is my transom going or did someone just not get them tight when they put it back together?
There was a pretty heavy bead of normal silicon around the entire gimbal to transom, is the gasket supposed to take care of that or should I put 5200 at the end of whatever happens?
(mercruiser part #55989A8)
now before you jump to rotten transom hear me out. I've been reading a LOT and from very reliable people on these forum they say it's pretty much impossible for those bolts (pictured) to come loose. From what I understand the square bit on the back of the built in "washer" goes into the transom plywood allowing you to tighten the nut with the nylon insert from the inside. From what I can see with the picture (can't see it with motor installed) the nut end of the bolt is against a metal flange
on top of the fiberglass. Am I understanding how it works wrong? I just don't understand how the bottom of the motor could be tipping out even if there was no transom installed. I have done the weight test, and if it moves at all it's no more than 1/16th of an inch. Previous owner (I just bought it a couple weeks ago) is no help. So is my transom going or did someone just not get them tight when they put it back together?
