Is my motor tilted to much?
Leeworthy23
Hey all, I am just wondering if my motor is tilted to much or if it looks okay to you guys. New to boating, only been out once, but want to make sure its all good to go.
. Anyways, here is JUST a pic for anyone who I offended posting a link
Dave
Andy'sDelight
Re: Is my motor tilted to much?
Did you just spam under the guise of needing help in order to get me to look at your ad? Me thinks I've been hoodwinked. :mad:
Leeworthy23
Nope nope. I honestly need to know. When I was out in the water the other day the motor titled out. Just wondering if the reason is because the motor tilt. You can check out my other post on here about the Motor lock and stuff. Im legit!.
To me, it almost looks like it should be tilted back towards the boat more, But not sure.
shrew
If he already had a JPG of the boat in order to post on kijji, then he could have easily just posted the pic in the thread. Let's give the poster some credit and assume it simply didn't occur to him to upload the same pic of the boat that he both JUST bought and JUST put up for sale on Sunday.
Barnacle_Bill
It looks a little much to me. I imagine the bow comes up quite a bit. Try different position until you find the best one for your rig.
Leeworthy23
In which direction. Prop towards the boat or away from the boat?
Andy'sDelight
Thanks for clarifying and sorry for the misunderstanding. I think you need to trim that down a bit (prop towards the boat). :D
Silvertip
Honorary Supreme Mariner
Since you are unfamiliar with how trim works, you need to understand "why" in addition to just getting an in or out answer. If you were to think of the propeller as being attached to a long lever (the rest of the engine) and you pushed straight forward on the prop, the boat would simply move straight forward. With the engine trimmed out (as you have it) the force is no longer straight forward but downward . Therefore the twisting force will try to bring the bow of the boat upward. Conversely the opposite is true if the motor is trimmed all the way in so the force is tending to push the stern of the boat upward and hence the bow downward. You need to experiment with trim settings. With two people in the boat the trim will need to be set differently (usually) than with just one. Since you don't have power trim, you can move heavier stuff forward if necessary. Proper trim is when the boat skims over the water (on plane) with the bow slightly high. If it gets too high the boat will likely porpoise (bow bounces up and down). With too little trim the bow will simply plow through the water. To answer your question, I feel the trim is a bit high. Move the motor in one hole. But make test runs with what you consider an average load. You won't know which setting is best until you try.
