Is my motor charging or not.
onlymee36
Just purchased an older suzuki DT55 outboard. Runs great and the tach works fine. 5400 rpms at WOT. My question is, I never have been stranded with a dead battery, but after reading many post on charging circuits and rectifiers going bad, I decided to check my charging voltage. I have a new marine starting battery installed. I charged it to full charge, and let it set over night. I installed it in my boat and checked the voltage at rest. It read 12.6 volts. Started the motor, checked it at idle still 12.6. Checked it while at WOT and still 12.6. I fished all day , stop fish, start etc etc. Even ran my eagle fish finder most of the day, which is run off the starting battery. At the end of the day after 8 hours of fishing I loaded the boat and decided to check the battery at rest. I was surprised to see it still read 12.6 volts. Does this mean that it is charging at some point, maybe takes a while to build up the voltage. I only checked it for like 5-10 seconds each time i did it. During the day it seems to be able to keep a full charge,,,,,.....or is my charging system shot because it doesnt go to say 13.5 at wot. I just dont want to get stranded some day because of faulty electronics. any information would be greatly appreciated.
Scott
RogersJetboat454
Re: Is my motor charging or not.
Welcome to Iboats.
Are we checking voltages with a voltage gauge on the dash, or with a Digital/Analog multimeter at the battery?
MH Hawker
It should be reading 12.6 while sitting and 13.6 at WOT while running directly at the battery terminals , not at the connectors. If it isnt then it isnt charging or it isnt getting to the battery.
onlymee36
Welcome to Iboats.
Thanks for the welcome............ I checked it with a digital Multimeter at the battery.
onlymee36
Thats what I thought too, but I couldnt understand how I could run the boat all day for 8 hours...stopping ......starting .....fishing etc etc. I even run my eagle fish finder while trolling and at the end of the day I still end up with a battery that still has a full charge. Should it always put out around 13.6 at wot or does it build up to that after running for a while. Like I said I only checked it at half throttle and at wot for about 10 seconds each time.
MH Hawker
The charging voltage will change with motor RPM`s, WOT is the max but I am not completely familiar with some of the newer motors and some may have a voltage regulator that may keep the charging voltage higher at lower RPM`s but at WOT it should be higher.
UncleWillie
If the battery voltage stays at 12.6 at WOT it is Not Charging! :(
The battery has a charging threshold of 13.2 to 13.5 depending on a lot of things. (Including acid pH, Specific Gravity, Temperature.)
It will charge Slowly at 13.6 but it will take Days to charge a nearly dead one.
You should be seeing 14.5 to 16.5 at WOT depending on the specific generator in the motor.
etracer68
Ensign
Your fish finder should also have a volt gage on it. You can watch it as you go about the day running the motor. Most have alarms in them that can be set to go off if it is over charging too.
onlymee36
Thanks for all of the great information guys. One question is that why is my Tach working. I thought it ran off of the charging pulses. Maybe I'm wrong or maybe it still could be a bad rectifier, or maybe a fuse could be blown? Any thing that I could check first to see why it isnt charging. Im no boat mechanic but any information you give me I would appreciate. Thanks in advance. :)
Scott
onlymee36
One more thing guys, does the motor charge the battery thru the same Starting connection, or is there a seperate wire leading to the battery from the motor. I have 3 leads coming from the battery. The big wire for starting, and 2 smaller ones which I think power my Fishfinder and bilge pump.
Scott
Silvertip
Honorary Supreme Mariner
The two large battery cables going to the engine take power FROM the battery during starting. When the engine is running the output of the alternator RETURNS the charging current to the battery through those same cables. The two smaller wires are part of the "Boat" electrical system and are totally separate from the the engine. They feed the fuse panel. switches, and any accessories. The gauges are powered via the "Engine" electrical system which is the cable that runs from the engine to the control box and igntiion switch and gauges.
UncleWillie
Scott
A fuse would be the first thing to look for, then rectifiers.
Your tach is working because it operates off of the Ignition Pulses that come from the Points (or equivalent), not the generator.
If you want to see what a normal battery looks like with the engine stopped, idling or reved up; go look at the one in your car. :cool:
