ScottWyler
Thread starter- Joined
- Jul 11, 2016
- 32
Hey guys I have an ox66 225 HP. Great motor but I’m having a little bit of an issue that I fixed but seems that it’s coming back again the issue that I had was that anytime I went over a wave when I would smack down off the wave my motor would surge ... it turned out that it was a clogged VST filter... since changing that filter I do not have any issues but now it seems that when I am driving the motor on flat calm water I do lose 300 to 400 RPM not as significantly though could the filter be getting clogged again? if so what could be causing the filter to get clogged again because when I changed it I also cleaned the VST tank and didn’t see much debris... i will attach two photos. they are both the same filter. one picture was taken when i took the filter off right away so it was wet. the other is like an hour later when it dried...
