Is my cooling system working right?
jbreitz
Hi guys, relative boating newbie here. I have a 115hp Evinrude that likes to throw the overheat alarm when I'm idling on land with muffs. I replaced the water pump, I'm getting a strong telltale. I replaced the thermostats last year, and it ran great the couple times i had it out. This year I fired up and almost no water comes out until it overheats and i shut it off. Still getting the telltale, and i get flow when i remove the tubes from the thermostat. Logically, i figured it was the thermostats again, so i removed and checked them and they seemed to open fine. What now? Did i put the pressure relief valves in backwards so hot water isn't getting to the tstats? Am i plugged up somewhere in the lines downstream of the tstats? I know nothing about this system past the tstat housing. If someone has some diagrams or ideas, I'd love some input! Thanks!
Bosunsmate
What years this?
Also if the little hole blocks up in some models in the thermostat housing you will get no flow which is why i always enlarge that hole.
Also being on muffs means you suck up a lot of air which creates a airpocket and if the telltale outlet isnt moved to the top of the crankcase then air will keep piling up there instead of being chased out by cooling watee
jbreitz
Thanks for the reply! This is an 82 model. Makes sense with the air pockets, I'll see what I can do to rule both that and the tstat blockage out and report back
interalian
Another way I've read for dealing with the tiny bypass holes getting blocked is to cut a small groove in the pressure relief valve. I imagine the benefit would be that every time you're running fast and the valve opens, the slot gets cleaned, whereas the tiny bypass holes may not.
I've had the same thing overheating on muffs, but I found my thermostats were sticking. Once I put them in a pan on the stove and brought the temp up, they snapped open suddenly, just as the water was around 180F. Worked fine after one cycle. The boat had sat for 3 years or so without use before that event.
emdsapmgr
Bosun is correct. (post # 2) You engine has two small holes in the valve body plate inside the thermostat housing. These are bleed holes. If either of them gets plugged up with sand, debris, that side of the block will surely overheat. Those bleed holes permit warm water to get to the back of the stat so that it heats up and opens. By the early 90's the material between the two holes was removed and it became a larger, single oval hole.
jbreitz
Well, sure enough, the bypass holes were clogged! I blew them out and they still seemed restricted, so I opened them up a few thousandths. It worked great! If i still have a problem with them getting clogged, I'll be sure to try interalian's trick. That sounds like a perfect solution to me, next time I have them out ill give that a shot. Thanks so much!
