Is my comp. test result is satisfactory
dianamanal
Hi to everyone,
I have done compression test on my outboard Force 70 hp,model 1991,and found 1-->120 psi,2-->122 psi,3-->120 psi.
Is my motor ok with above gauge reading or needs piston rings replacement ??
Thanks
Bigprairie1
Re: Is my comp. test result is satisfactory
You didn't mention if the readings were from a dry or wet test however either way, those readings are fine and within good operating specifications.
BP;):):cool:
dianamanal
Thanks for your reply,Reading were from dry test.
Thanks
jerryjerry05
Those are good readings.If it had been off on 1 cylinder say 120-80-120
That would be a problem.
You should do a de-carb once a year.More often if you use the boat a lot.
Mercurys Power Tune or Sea Foam do a good job.Any PM on a marine moter is a good thing.
One of the worst things for a boat is letting it set.J
dianamanal
Thank you all.
Any advise how to do de-carb ?
jerryjerry05
Can you get either product? Local Mercury dealer should be able to help.
I don't know what's available as far as auto stores but Sea Foam should be found. Then follow the directions.J
jason32038
seen seafoam the other day at o'reillys wasnt cheap though. Might be cheaper elsewhere.
dianamanal
Thanks,I'm gonna check what we got here in Sydney
