deltacottonboy12
Thread starter- Joined
- Nov 24, 2007
- 12
96 Merc, 4 cyl, 40EO with electric tilt, tiller. 1652 Alumacraft-pitch 14
prop is blowing out just as the boat is on plane. I can cruise around on plane but if i try to accelerate the prop just starts blowing out or spinning in any tilt position.
The motor has a TON of splash back while moving. so much that i can not see the cavitation plate due to all the splashing.
also, if i am at a dead stop, and i give it a good bit of gas to get a hole shot, the prop just spins until the boat hits a certain speed and then takes off onto plane the starts spinning again..
here are some pictures from my phone. Cav plate is about 2 inches below the bottom of the boat.. I was told if i raised the motor this may solve my problem.
