On the Starcraft forum a guy had just totally restored a beautiful 22ft runabout . He splashed her for the first time and on the way home the hitch popped off , the tongue nosedived and every weld failed - winch post ,tie downs and the safety chain welds.If you are good at welding and can do it correctly it will be stronger than bolts but of course permanent. Plus make sure it's positioned correctly. With bolts it's adjustable.
Moral of that story here has me wondering what would have happened if that hitch had not "popped off".On the Starcraft forum a guy had just totally restored a beautiful 22ft runabout . He splashed her for the first time and on the way home the hitch popped off , the tongue nosedived and every weld failed - winch post ,tie downs and the safety chain welds.
Boat skated right through a fence beside the highway and ended up 150ft away in a field with major hull damage!!!!
He attributed the total failure to fatigued welds.
If yur gonna fix up that old decrepit looking trailer it looks to me like the major fatigue failure point would be the welded hinge pin at the bottom of the swinging post where the bow eye slots.
Totally depends on how much high speed towing you do as to how far you want to go !!!!
Then the welds were not properly done. A proper weld will be stronger than the metal surrounding it. If you don't really know how to weld then yes bolts are better.He splashed her for the first time and on the way home the hitch popped off , the tongue nosedived and every weld failed -
I am the worst case senario kind of guyThen the welds were not properly done. A proper weld will be stronger than the metal surrounding it. If you don't really know how to weld then yes bolts are better.
Look at almost anything out there such as trailers, cars, race car frames, bicycles, motorcycles, heavy equipment, etc... plenty of welds.
