Is it possible
93nitro
Before I installed my 115 Merc lower unit I forgot to check if it was in neutral. Test started for a few seconds and realized lower unit is in drive. When shut down I turn the prop one direction it clicks, and the other direction it turns the motor over. Haven't got the controls hooked up to it yet so was wondering if it is possible to get it in neutral without taking the lower off again?
PHE
Re: Is it possible
It will click in forward in one direction.
I haven't work on that particular motor, but I'm pretty sure you have to drop the lower unit and put the controls in the right gear, then put it back on.
