Re: is it my power packs or stator
Are you saying the flywheel won't turn(engine won't crank)? Switching the boxes won't stop it from cranking, you now have seperate problems.
I think rush probably means fire, instead of crank. Most newbies mix it up and don't realize how important it is to choose words that describe exactly what is happening.
Anyway, back to the OP's problem. There's a remote chance that something took out the first switchbox (Mercury term for power pack) and the same fault took out the second one when you swapped them.
More likely, however, is a common fault that got a bit worse, such as low output from the stator, or a resistive or intermittent gound fault on the kill circuit. Another common fault is slow cranking speed. It needs to spin over briskly for the stator to put out enough to the switchboxes to make a spark.
At this time, double check all your connections to the engine wiring diagram before you proceed. If you don't have a diagram, don't proceed till you get one.
Then, try disconnecting the kill wires from both switchboxes and try to start it. If it starts the problem is in the kill switch, ignition switch, or wiring. Choke out or disconnect the fuel from the engine to kill it.
After that, you need a DVA, and maybe a spark tester to continue.
hope it helps
John
