Re: Is anyone good with Volvo Penta Sterndrives??
Capri Restorer,
Reply to Trackbolt
(Thanks again for the replies.) The drive on my boat is a VP 270. I had a question about the drive also. I recently put the main belt on the front of the engine (alternator-cylinders). The prop turns freely in a reverse direction, but it is very hard to turn it in the right direction. It did not do that until I put the belt on the engine. Will the bearings need to be replaced, or is it just the belt on the engine.
Will this affect the engine also??
You asked me this question in the restoration forum and I will try to answer it here. How are you turning your prop with the starter cranking the engine or by hand? I have never tried to turn my prop with the out drive in forward or reverse. I cannot imagine it being very easy. I assume the belt you are speaking of is the accessory belt. That or the timing belt should not affect what goes on with the stern drive. Are you sure the sterndrive was in neutral? The prop should turn freely in either direction with the sterndrive in neutral. You should not be able to turn the prop by hand with the engine in forward or reverse.
Capri Restorer,
Reply to Trackbolt
