is a valve cover the same as a cylinder cover?
waitsfan
I have been asked to remove the valve cover and look at the valves...but, stupidly, can't find it/them in the SELOC diagrams for my 70hp 2-stroke outboard.
help?
rodbolt
Re: is a valve cover the same as a cylinder cover?
yep.
purchase a real manual.
a 2 stroke 70 has no valve covers.
what issue are you trying to resolve?
the seloc isnt much good for toilet paper, to rough and no color pictures in the brassire section.
in fact no brassire section :(
waitsfan
ok....will get a real manual.
I have no compression at all in the first cylinder. A colleague (with much more engine experience than me) suggested that, instead of giving up and putting the new 4-stroke engine we have in storage on the boat, I first try spraying sea-foam into the faulty cylinder and trying to run the engine for a couple of minutes and repeating that several times.
also he suggests:
(1) remove the valve cover (easy)
(2) take out all plugs
(3) inspect valves for your dead cylinder
(4) run the starter motor and watch the valves to see if they are moving freely
(5) you might have a piece of carbon stuck in the valve or it may need adjustment (valve adjustments are easy and all you need is a feeler gauge which costs a few bucks at most at the auto parts store -- hell for that matter a compression guage only costs around $30
(6) if you can't tell any difference among the cylinders then put the engine in the cycle where the valve should be closed on the exhaust stroke and blow compressed air into it and listen for air coming out and then do the same thing for the intake valve -- these engines are pretty simple and if its a cracked head gasket or head or something else - air will be leaking out in other areas....
(7) if it is then put the new engine on it -- otherwise adjust all the valves and clean the thing with some decarbonizer right in the plug holes and then run sea foam in the gas for the first few boat trips
This all sounds good to me (what do I know?)...but, like I said, I can't find 'valve cover' in my d$%n manual! What manual do you recommend for the Yamaha???
waitsfan
my colleague just corrected himself....he was thinking our engine was a 4-stroke, not a 2-stroke. He apologized and gave me some better advice.
We will try some things out...and then most likely take the engine off the boat.
Next I'll be asking lots of questions about converting an engine from tiller to remote!
