is a marine carb required??
lime4x4
If you no longer run a mechanical fuel pump (running electric fuel pump) is a marine carb still required? Since u no longer have the danger of a ruptured diaphram. Just curious
Maclin
Re: is a marine carb required??
Yes. The fitting for the fuel pump clear tube is not the only thing different about Marine carbs.
Ayuh,... Yes,.. Always, regardless of how the fuel gets there...
180shabah
Can I smoke at the gas station, if I smoke imported cigars instead of the local cigarettes that are know to cause cancer, low birth weight, yellow fingers and poor vocabulary????
mikeneal
Yes.
Very required. A local express cruiser just blew up here in Tampa Bay last weekend, badly injurying lots of people. Gas fumes are nasty and everything must meet CG requirements.
bruceb58
As a side question...You have the electric fuel pump controlled by an oil pressure switch so that it doesn't run when the key is on but the engine not running?
Gary H NC
Lets hope he does....:eek:
180shabah
I'm guessing wire nutted to some lamp cord run to the accessory plug on the dash.
lime4x4
Can always count on good answers around here with alot of ASSUMING actually it's hot wired to the battery with bare wire
