Is 5500 rpm top on a 85hp force
gotafixboat
I have a 1988 85 hp force and I will be running it on a 14 foot Hydrostream Vandal that I picked up for $100 and spent the winter restoring. I will be starting with a 21p prop. My question is if this setup runs a little over 5500 say about 6000 does my force stand a chance of stating in one piece? Hope to test drive soon.
Frank Acampora
Re: Is 5500 rpm top on a 85hp force
This one runs 5900 with a 21 pitch prop. No, you won't lunch the engine. They are short stroke engines with no valves to float. They are probably capable of 8000 or more, but of course, over 6000, you are out of the power band.
This boat is a 14 foot flat bottom. Your 85 will probably not turn 6000 with a 21 pitch prop, more like 5000, and speed should be up around 50--depending upon how fast the Vandal hull is. Start with the cavitation plate about one inch above the vee and use a cupped prop. Use the bottom holes so you can lower the engine if it cavitates excessively, however, my experience is that these engines will run one inch high.
If it is a really fast hull, be expecting chine walking unless the hull has a bottom design to prevent this. Carry at least 9 gallons of fuel because you will be running full throttle all the time and you will be able to watch the level go down. I carry 15 gal in this 14 footer.
At these speeds in this size boat, a "man- overboard" or "Dead Man's" engine kill switch is a MUST, and wear your life jacket AT ALL TIMES. This photo was taken in october and the jacket is under the sweatshirt.
Oh, yeah! Here are a couple of photos of transom reinforcement with .080 aircraft aluminum to handle the power.
gotafixboat
from what I have read about this hull it is fast but it is also prone to chine walking. It is a padded v hull.
Faztbullet
Thats a good little hull and you will have to learn to "drive" it especially with the blunt unit on that model force, expect around a 45-50 mph range and that hull really preforms good with a 3 cylinder Johnrude
gotafixboat
I finally got to try her out. The only thing with out ice was the river so I loaded up two batteries, two full tanks of gas, one tool box, and a bunch of warm clothes. Good news I didnt need the tools or spare battery and It was to cold to get into the second tank. Every thing worked well except the spedometer. I was running a 21p ss prop and my top rpm after playing with the trim was 6200 rpm. I had a lot of weight in the stern so the boat would ride very nose high untill it went on plane. Chine walking seemed to be no issue but I did install hydralic steering that may help. I think I need to get some wieght forward and possibly try a differant prop.
Bob
