Re: Is 29mph what I should expect?
Hard to say whether that's as fast as that boat will go. I also have a 15' trihull (see below), but it's a light one (700 lb). I have a 35hp motor on mine. It does 25 mph (GPS) at full tilt with just me in the boat.<br /><br />It depends on hull design, weight, and about a zillion other factors. The only way to tell, really, is to have a tachometer on board so you can tell if your outboard is reaching its rated RPM at WOT.<br /><br />If it is, then you're probably hitting the right speed, even if it seems a little low. If not, then it's time to re-prop and get a few more MPH out of your boat.
