ipilot 70 lbs thrust 24 volts power set up
donbou35
I have an powerdrive v.2 ipilot 24 volts 70lbs thrust motor.Im not sure what size circuit breaker to use,wire size between 2 batteries,plug and receptacle to use and wire size for 27 feet of wire going to back of boat to charging battery...I will use a mk 315 d 3 bank 5amps charger for this set up...Was thinking of using a 50amps breaker and #6amp wire...but not sure if this is ok...please someone help me i need to get this thing set up before fishing season opens... thanks in advance...
don
