Bgriffin67
- Apr 15, 2003
- 22
Question.. <br /><br />I'm working on a 19' Sunbird, since I have to replace the floor, do I need to cut out and rebuild the engine mounts (look like they are just fiberglass - the wood may have just rotted - off to either side of the stringers) or do I cut around these and just do the floor around it. The IO sits right over the open stern portion of the bildge so...<br /><br />If I don't pull the engine out, will the supports hold when I cut the rear portions of the floor out? I need to get the whole floor out to do the stringers.. <br /><br />And lastly, any suggestions on pulling the engine out when you're working outdoors on a sandy surface.. Guess I'm building a large hoist?
