yellowchap
Thread starter- Joined
- Aug 14, 2005
- 6
Hope you electrical guys can help for I am puzzled and in desprite need of help, sooo here goes.<br /><br />I put a coleman 2000w inverter in my boat along with a new 3 position source switch. The switch replaced a 2 position. Wired everything up, checked shore power first. Works great. Checked inverter and have the reverse polarity light on but only on the individual circuit breaker panel (the one with the test light) not the source panel. The reverse polarity light on the source panel does not come on. With shore power everything works great. Wired everything by directions. Checked and rechecked wiring.<br /><br />Could it be the way the inverter is wired on the inside from factory? This inverter has a outlet on it so I plugged in to it and run straight to the source panel.
