Invader aq271c/DP-A trim just clicks?
bransjeep
today i installed my outdrive and my trim tubes werent at the right length to match up so i jumped in the boat and tilted it down, the trim pump came on for a few seconds and then stopped now all the darn thing does is click. maybe solenoids behind relay? fuses..im not sure were they are?
Don S
Re: Invader aq271c/DP-A trim just clicks?
Volvo only uses relays, no solenoids. Sounds more like weak battery, loose or corroded connections somewhere, including loose grounds.
bransjeep
as always Don, thanks i will follow up with my results
bransjeep
Well.... After much frustration cleaning the connections and replacing both relays which didnt work.. Then i decide to re- wire the trim relays only do i find that there was no direct power to them... The previous mechanic must have removed it??? Well at least its all new
Don S
At least you found the problem, and understand your trim system a bit more. That's a good thing ya know. ;) :D
