Mizz Mayfloat
Thread starter- Joined
- Aug 30, 2005
- 29
Got the passenger side head off. Does seem a bit warped using a carpenters square. Going to check with a good straight edge and feelers guage this evening. It does not show any signs of having a bad gasket.<br /><br />I did find in the #1 cyl an exhaust valve with a spot on it where carbon got stuck on the seat. Probably why the compression was down a bit more than the others.<br /><br />Going to pull the drivers side off tonight and see if there is a problem there. I'm thinking about just getting a remanufactured set. For under $400 seems cheaper than to have these heads reworked. Just unsure about remanufactured componets sometimes.
