chiroflorida
Thread starter- Joined
- Jul 19, 2015
- 1
I have a 1987 Evinrude 140 that has been difficult to diagnose, but I think I may have found the problem. Here are the details:
Symptoms:
-Hesitation lasting 2-7 seconds around 3200 RPM when trying to get on plane.
-Intermittent "rumble" noise through all RPM range.
-Trouble idling without stalling once warmed up.
Tests: (positive findings in bold)
-Good/even compression.
-Spark jumps 7/16 gap with strong blue snap, but drops erratically on all cylinders.
-Timing light confirms intermittent spark drop,but no "double firing" while observing timing on flywheel.
-Choke and fuel primer bulb squeeze made no difference. Cleaning the carbs made no change.
-Replaced power pack with no difference.
-Replacing the spark plugs made no change.
-Continuity (ohm) tested normal among the leads and leads to ground on ignition coils, Sensor coil (trigger), and Charging coil (stator).
-DVA voltage tests were within normal on the trigger and stator when cranking.
-DVA voltage of 30-40 volts detected from stator to ground when cranking.
-Checked insulation on stator wires and saw nothing abnormal. No melting, dripping, cracking or signs of rubbing.
-Flywheel magnets are molded in as they should and seem strong.
Solution:
-Replaced the stator and the intermittent spark problem is gone. No voltage leak from the new stator.
The only thing left is to test it on the water and see if the hesitation disappears along with the "rumble" noise.
Hope this helps someone with similar problems.
Symptoms:
Solution:
