Kelvin Simmons
Thread starter- Joined
- Mar 22, 2010
- 11
My 60 hp Johnson runs intermittant speeds.. at low or hi speeds.. and is very slow to plane out of the hole... The bottom cylinder seems not to be doing anything, toook the cyd. cover off and bottom cyd. walls look smooth... I checked the coils and actually moved them around nothing changes, also moved the spark plug wires around... installed a new power pack, this did not help.. I notice when I take the sparkplug wire off the 3rd cylinder while idleing, nothing changes... it is almost as if the 3rd cylinder does not work at all.. when i take the spark plug wire off with pliers, there is a good spark from the wire to my metal pliers.. when i take one of the top two spark plug wires off, it goes dead immediately. I have recently had the carbs rebuilt so it should be getting fuel.. Any help is appreciated.
