intermittant power
twhawkman
HELP !!!!!! Please<br />16 YEARS OF TROUBLE FREE USE AND I MEAN TROUBLE FREE BUT NOW THERE ARE PROBLEMS. IT STARTED AND IDLED FINE BUT WOULD NOT RUN AT FULL THROTTLE. I CHANGED PLUGS, HAD THE COMPRESSION CHECKED AND HAD THE CARBS CLEANED AND USED FRESH GAS. THINGS WERE FINE FOR THE NEXT ~5 TIMES OUT THEN IT WAS BACK TO ITS OLD TRICKS BUT EVERY SO OFTEN IT WOULD RUN FINE AT FULL THROTTLE. I HAD IT CHECKED AT A MARINA WHILE OUT FISHING AND HE DETERMINED THAT THE TOP COIL WAS BAD, I CHANGED IT BUT NO IMPROVEMENT, IT STILL ACTED THE SAME. WHEN IT'S NOT GOING TO RUN IT WILL NOT IDLE BUT IF IT IDLES WHEN IT'S IN NEUTRAL I KNOW IT WILL WORK. IS THERE A HIGH SPEED JET? COULD IT BE PLUGGED? WHEN HE WAS TESTING IT, HE USED A TESTER LIGHT AND WHEN HE JUMPERED OVER THE TOP COIL TO THE POWER PACK? IT IDLED FINE. WHAT'S HAPPENING HERE? HELP!<br /> TWHAWKMAN
93bronco
Ensign
Re: intermittant power
you didnt give year, hp or model #.<br />also the caps are like screaming at everyone.<br />thanx
