intermediate orfices missing?
hondarider188
I have a 1984 evinrude 140, I noticed that in one carburator I have a set of intermediate jets (#25) and I the other carb It doesnt have any intermediate orifices. Both carbs have the same part # and look the same, but one of them( the top one) just has holes where the orifices would go but , no jets, no threads,and the holes are slightly smaller than on the carb with jets. Possibly the wrong float chamber? Does any one know why this would be? The moter dies when you give it throttle slowly, and doesnt idle very well , mabe this is the poblem? I am considering drilling and tapping threads for #25's. any info would be appreciated thanks.
BonairII
Re: intermediate orfices missing?
Did you just get the motor? If not, has the motor always run bad?
emdsapmgr
It's always possible the bowl is defective from the factory. Certainly, it's an unusual situation. The running problems may well be attributed to this bowl defect. It's also interesting that this engine came with two different bowls from the factory. The upper and lower are different part numbers. Unusual. Your original upper factory bowl is no longer available-has been superceded to 392375. That bowl is also NLA, but there are some dealers around that still have new stock on it on their shelves. If you don't want to fuss with drillng and tapping, you can buy a new one from a Bombardier dealer: The Ulrich dealer has 4 of them in stock.
ULRICH MARINE CENTER 16955 ST. HWY 13 BRANSON WEST MO 65737 (417) 272-1841
US BOATWORKS INC 930 OSAGE AVE KANSAS CITY KS 661051850 (913) 342-0011
hondarider188
i just got it and i dont know if it always ran this way. but i do think i will try to drill and tap it first because if it doesnt work i will have to buy one anyway and thanks for the info
hondarider188
well i went and drilled out the carb and put in jets and it worked great the idel is much better and the intermediate is great and i think it even helped out the high speed a little two so glad i did it and thanks for the help.
