VisionIsle
Thread starter- Joined
- Feb 10, 2006
- 98
Volvo AQ240A / 280
Well the haul out has begun. I found water in the u-joint bellows, which I expected due to a broken clamp. The upper gear housing is off and with the u-joint assembly came the broken seal ring. The u-joints show no rust or play, I am having them checked regardless and possibly replaced tomorrow.
With the seal ring out I was able to see the intermediate bearing. No signs of rust, however, I am able to spin it around the shaft freely. I was told this should not spin at all, is this correct?
There is also a slight amount of play in the shaft. Hard to determine but about 1/64". I was also told that there should be no play at all, Is this correct?
Finally, I do not have the cash to pull the engine and replace both bearing on the drive shaft so I am going to clean out the old grease and re-pack with new, add the new seal ring (with the spring channel facing the stern drive).
Replace the bellows and deal with the vibration.
What are your opinions on this?
Thanks,
Carden
Thanks,
Carden
